Can I import the 3d cad model into ideCAD
ammer
Kıdemli Üye
Dear friends
i have a 3d modeling for the steel frame,
i want to import it into idecad to completing it easily.
    162.9 KB · Görüntüleme: 405
Re: Can I import the 3d cad model into IDECAD?
Dear User,
You can easily import your 3d model into idecad. The 3D model should be in dwg format and should consist of simple lines. You can use the "dwg/dxf As Structure" command.
Best Regards...
    128.5 KB · Görüntüleme: 383
Hello friend
Thanks for your efforts
I will try it and inform you
