Correct option for the beam or wall connection to the column
ammer
Kıdemli Üye
hello friends
i would like to know the correct option for the beam or wall connection to the column
and is it correct in the below image?
or must be connect the beams and the walls to the center of the columns ?
thanks
    65.1 KB · Görüntüleme: 2,074
Re: Correct option for the beam or wall connection to the co
Hi Ammer,
It's not required to connect the walls or beams from center of the columns.
The connections on the image you added is no problem.
