Does ideCAD show the stair section in the drawings?
ammer
Kıdemli Üye
Dose idecad show the stair section in the drawings?
    103.6 KB · Görüntüleme: 3,270
Re: Dose idecad show the stair section in the drawings?
ammer":oe2kk93f' Alıntı:
Hi Ammer,
Check "Object Body" Color on Drawing Setting if it's white. Stair section is being showed but you may not see because of it may be same color with background color.
    25 KB · Görüntüleme: 3,249
idecad dosen't draw the stair shape?
dear friendds
    167 KB · Görüntüleme: 3,200
Re: idecad dosen't draw the stair shape?
Hi Ammer
I answered your same question on this following topic.
If you couldn't solve your problem, please add your project
Re: Dose ideCAD show the stair section in the drawings?
dear hakan
it still not showing even though i changed the color to the black,
here you are my file
thanks
Hi Ammer,
There is no stair section on your current drawing as you mentioned yes but I didn't see any problem on stair section drawing after redrawing.
1. I opened your project
2. I got stair drawing. there was no problem stair section lines.
Please let me know if you can't succeed to get stair drawing without problem after redrawing.
Furthermore I want to notify you that stair analysis was not applied on your project. You need to define stair boundary conditions to solve separate stair from building.
    57.8 KB · Görüntüleme: 3,172
dear hakan
it still same issue
    124.7 KB · Görüntüleme: 3,159
hi hakan
kindly send me any stair model made by you...i will try the settings.
hello
i deleted the stair drawing in your model,and tried to set drawing again,but the issue didn't solve. :( :( :( :( :(
Dear Ammer.
Please look.
Do you have closed layer?
Problem solved, which was related to hasp connection issue.
