from the ideCAD link idecad knowladgebase
a compassion between etabs and ideCAD
done by Mr. İsmail Hakki BESLER
how did they obtain this values?
by regards
When calculating the ratio, "the area of the rectangular section / the area of the t-beam section" is used. If you read the "Modelling Steps", you can find the answers.
hello nurgulkaya
I appreciate your efforts for your answer
but still i can not understand how did obtain the value of the mass for the beams section
would you please do the equation for this beam section manually here?
