How to correct the font of the detail?
ammer
Kıdemli Üye
hello dears
in the below image for the flat slab reinforcement,i want to get the same font size.....how can i do it?
    90.9 KB · Görüntüleme: 1,725
ammer":2co5l56x' Alıntı:
hello dears
Hi Ammer,
Which text you want to make same size with which one's size? can you explain your question more?
hi hakan
the two total length that i pointed in the red line....
ammer":37nozesi' Alıntı:
hi hakan
Hi Ammer,
Give same value on both "steel text" and "Total reinforcement lenght" on" Drawing Properties", which you will see before drawing framework plan. See the picture below.
    32.5 KB · Görüntüleme: 1,670
dear hakan
i mean that the text 1 is smaller than text 2
how to get same height font
    99.9 KB · Görüntüleme: 1,631
ammer":2z72nm2l' Alıntı:
dear hakan
Hi Ammer,
Text heights of auxiliary reinforcement bar might be automatically scaled to along bars to fit small reinforcement bar. You may change them manually by exploding block texts after drawing framework plan.
hi hakan
it was forming automatically .....i didnt edit it.
ammer":18y0rtj6' Alıntı:
hi hakan
Hi Ammer,
You need to edit after drawing formwork plan if you want to make same size.
1. Select the text.
2. Click right button of mouse on it.
3. Select "explode" command from appearing menü list
4. Explode Type dialog will be appeared.
5. Select "explode all" and click Ok.
6. Now you may select texts that you want
7. Click right button of mouse on text.
8. Select "Edit text" command from appearing menü list.
9. Change text height from there and click ok.
10. change height for per text that you want by doing 6-10 steps.
    29.7 KB · Görüntüleme: 1,578
    9.6 KB · Görüntüleme: 1,578
    27.2 KB · Görüntüleme: 1,578
    28.2 KB · Görüntüleme: 1,578
