How to create a private template
ammer
Kıdemli Üye
HI HAKAN BYE
I WOULD LIKE TO CREATE A PRIVATE TEMPLATE USE IT IN ALL PROJECTS ,HOW TO DO THAT PLEASE ? :D :D :D
ammer":3vb0soub' Alıntı:
HI HAKAN BYE
Hi ammer
Simply, do all your settings in any empty project and save it with any name. Put the file you saved into folder named "C:\Program Files\ideCAD\ideCAD Structural 8\Templates\structural". You may create a folder in there as well.
For example, on this picture I created a folder named "my template" under the "C:\Program Files\ideCAD\ideCAD Structural 8\Templates\structural". And I put sample "my template.ide85" into it.
and now, run the program, select the file on new project screen
    39.1 KB · Görüntüleme: 3,917
    45.4 KB · Görüntüleme: 3,917
    44.1 KB · Görüntüleme: 3,917
Thanks hakan
I mean i want to create a template by autocad file then import it in the idecad
ammer":1d2g849g' Alıntı:
Thanks hakan
No, you have to make all settings in an idecad file for beams, column and other objects, You can also set analysis options.
hi hakan
thanks for your tips,
i want to set all my out put drawings by the attached autocad template....not the saved idecad drawings template... :D :D :D :D
    26.5 KB · Görüntüleme: 3,855
ammer":572l5qp9' Alıntı:
hi hakan
Hi ammer,
I see your question now.
Import autocad drawing into idecad you want to use. (use "Dwg-dxf-2d" command under "file" menu ). Scale it if its necessary.
Make block it to file as .blk object in idecad. (use "Copy to file" command under "file" menu )
Now you may paste .blk object from file into any your plans, detail etc you will create in idecad. (use "Paste from file" command under "file" menu )
i did not understand ,please mr hakan if you could show them by images... :roll: :roll: :roll: :roll:
1- Import autocad drawing into idecad you want to use. (use "Dwg-dxf-2d" command under "file" menu ). Scale it if its necessary.
2-Make block it to file as .blk object in idecad. (use "Copy to file" command under "file" menu )
3-Now you may paste .blk object from file into any your plans, detail etc you will create in idecad. (use "Paste from file" command under "file" menu )
    43.3 KB · Görüntüleme: 3,828
    47.4 KB · Görüntüleme: 3,828
    47.2 KB · Görüntüleme: 3,828
    53.5 KB · Görüntüleme: 3,828
    67.9 KB · Görüntüleme: 3,828
hi hakan bye
thanks to your efforts it was very clear..
but i want to put this block saved shows in all drawings as a layout(ex. for beams +columns,formworks,walls.....foundations details)
    154.4 KB · Görüntüleme: 3,817
ammer":39tiffa0' Alıntı:
hi hakan bye
It cant be done automatically, you should put it manually on each layouts, delete other lines created by program that you dont want and put your block. Move it to its location.
