How to delete any loads combinations
ammer
Kıdemli Üye
HELLO FREIND
HOW TO DELETE ANY LOAD COMBINATIONS THAT I SELECTED BY THE COLOR HATCH?
    39 KB · Görüntüleme: 1,364
Re: How to deletre any loads combinations
ammer":1jyd2ndm' Alıntı:
HELLO FREIND
Hi Ammer,
Those combinations are automatic created combinations for Turkish Seismic Code and TS500 Standard. You can't delete them. However you can add your own combinations on user defined combinations section.
Furthermore if you don't want to consider seismic effects in your project, you may give "zero value" to "Building important coefficient" on Analysis Settings.
    45.4 KB · Görüntüleme: 1,315
HELLO MR. HAKAN
I'M CONCERNING THE SEISMIC LOAD BY NOT IN TS CODE....
OK IT'S CLEAR....I WILL ADDING MY COMBINATIONS.....
THANKS TO YOUR COOPERATION
