How to fix the analysis issue
ammer
Kıdemli Üye
dear friends
I got the below issue while doing the check mode
please need your recommends
    230.5 KB · Görüntüleme: 900
Re: how to fix the analysis issue?
ammer":2xkkngvw' Alıntı:
dear friends
Hi Ammer,
Your project defined very far away from origin location(see the object coordinates). Program recommends you that you should define project near origin location. in order to that, click 3d view wih all stories, select all objects(ctrl+A) on 3d view and use move command to move all to near origin location. If you add project to message, I can do that for you.
Hi again,
Use "Zoom Extents" command, then you will see the blocked objects that existed far away from origin location. Delete them or move them to near origin location. Your issue will be fixed.
Here is fixed project:
WAW
YOU ARE RIGHT
MAYBE I IMPORT DWG FILE WITH ERRORE UNITE
THANKS AGAIN FRIENDS
:D :D :D :D
