How to solve the beam overlap
ammer
Kıdemli Üye
HI FRIENDS
HOW TO SOLVE THE BEAM OVERLAP FOR THE BELOW IMAGE
I WANT TO SOLVE THEM AUTOMATICALLY NOT MANUALLY BECAUSE THEY ARE A LARGE BEAMS
THANKS
    419.9 KB · Görüntüleme: 1,139
ammer":25iwu41i' Alıntı:
HI FRIENDS
THANKS
Hi Ammer,
Add your project, let's look if there are column-beam connection problems in your project. Probably you defined beams with different offset in itself from column to column as uncontinued.
Hi Ammer
While defining beams, snap the columns. Define the beams from column to column for each left and right end.
