How to solve this issue in the ribbed slab
ammer
Kıdemli Üye
hello friends
I have an open in the ribbed slab,
when i drew the open by the slab option, the ribbed did not delete,
how to solve it?
    124.9 KB · Görüntüleme: 2,210
Hello Ammer,
You should use slab edge commend. You should draw slab contour and opening with slab edge commend and then define the ribbed slab.
*** In the rib and waffle slabs, the slab openings cannot be defined so as to divide the beams. Statically it is not appropriate to define the rib on the cantilever, it is appropriate to support the ribs on the secondary beam.
    60.3 KB · Görüntüleme: 2,156
  • olması gereken.ide10
    333.1 KB · Görüntüleme: 263
    59.3 KB · Görüntüleme: 2,153
