P delta effect
ammer
Kıdemli Üye
hi admin
I want to know how the idecad checking the model if it needs to presetting the p delta analysis effect or not...
if it needs, how to completing the steps?
hi admin
it's very important to takes me the advice :? :? :?
Dear User;
In order to define the p-delta analysis case, "Static nonlinear analysis case" should be defined in the "Analysis - static analysls section" of the "Structure Tree". How the P-delta analysis case is defined is shown in the picture below. P-delta analysis results can be used in steel or concrete element design bu using the options in the element design section on the "Static nonlinear analysis" screen.
    158.9 KB · Görüntüleme: 318
    14.9 KB · Görüntüleme: 318
hi oguzcan i missed you :D :D :D :D
would you please give me the p delta load case according to the Turkish code?
and where the idecad put the p delta reports?
Dear User;
There is no specific combination in the Turkish Earthquake Code for P-delta analysis. The p-delta effects are only considered in the design results by defining the Load Case. For this reason, a special report is not created for p-delta analysis.
Best Regards...
