please need explain in attached image....
ammer
Kıdemli Üye
hi
have a good time to all members.
i need an explanation for the attached image concerning of the shear wall.
by regards
    117.9 KB · Görüntüleme: 1,919
ammer":3vo5ah9a' Alıntı:
hi
by regards
Hi Ammer,
S.R.Perc means "static required percentage" calculated by design effects (S.R.Perc=AsCalculated/SectionArea). Negative means there is no need reinforment bars for this shearwall but please attach your project as well. let's see in your project if there is a problem for negative percentage calculating.
dear hakan here you are the attached file
please review it
ammer":3ux8ar3q' Alıntı:
I'm very sorry mr. hakan
here you are and download it from this link
There is no problem with analysis model. you selected earthquake effects are as zero and only vertical loads exist in project. Like I wrote above, minimum design effects applied to shearwall section, there is no required reinforcement bars for shearwalls.
