Quaries..??
ammer
Kıdemli Üye
Dear All, I have some queries, I hope you can answer them, and thanks to all whom will participate:-
1- Can I get the total quantities of steel required, just like, in idecad Baeton ?
2- When I used a composite beams, the drawings comes out, without the shear studs..!! and not referred to even with a text note.
3- Some American sections are not included in the section library, like (Hp). Is there anyway to overcome this problem. For now, I have a big project (working on), and to be honest, I wanna use Idecad to get drawings (instead of Tekla)+quantities (when I check the idecad from a structural point of view, I will use it for design of coarse).
Thanks. Regards
Hi Ammer;
1- You can get total quantities of steel in subpart of the reports that it's named ' Single part and assembly' .
2- Steel drawings are in progress now. Composite beams details are not finished.
3- You can add the section at Stucture Tree Section part. You should click right and select add new section.
    57 KB · Görüntüleme: 3,171
    50.5 KB · Görüntüleme: 3,171
    12.2 KB · Görüntüleme: 3,171
    73.3 KB · Görüntüleme: 3,171
