Where to find punching shear Steel
ammer
Kıdemli Üye
HI
I HAVE A FLAT SLAB IN MY MODEL
THE SHEAR PUNCHING RESIST OPTION FOUND IN THE COLUMNS PROPERTIES,
HOW TO ACTIVE IT AND IF THE SLAB NEEDS TO DO THIS OPTION
WHERE CAN SEE IT IN TH EDRAWINGS?
    104.2 KB · Görüntüleme: 325
Re: WHERE TO FIND THE PUNCHING SHEAR STEEL ?
NEED UN ANSWER PLEASE ?
Dear User;
If punching reinforcement is required for a column, it is given in the "Raft foundation punching check" report. If punching reinforcement is required, it can be checked by selecting the appropriate punching reinforcement from the "Column Settings"(as you send in the picture). When you select one of the punching reinforcement types, you activate the selected punching reinforcement.
However, the drawings of punching reinforcement are not made automatically. You have to do it yourself by examining the raft foundation punching report and using 2 dimentional display.
Best Regards...
HI FREIND
THANK SFOR YOUR EFFORTS :D :D :D
IS IT POSSIBLE FOR FLAT SLAB OR ONLY FOR RAFT FOOTING?
WOULD YOU PLEASE SHOW ME THE PUNCHING STEEL REPORT?
IS IT IN COLUMN OR RAFT REPORT?
Dear User,
You can see the Punching Reinforcement Report at the end of the Raft Foundation Punching Check report.
It is included the raft foundation report for the punching reinforcement report.
Best regards...
    260.3 KB · Görüntüleme: 259
I CHANGED THE SEISMIC CODE TO TD2018 AND IT'S WORKING TO APPEAR THE PUNCHING CHECK
THANKS ALOT FOR U EFFORTS
