Why the(cantilever beam and slab) do not transfer together
ammer
Kıdemli Üye
hello
    56.4 KB · Görüntüleme: 3,157
    66.1 KB · Görüntüleme: 3,156
Re: Why the(cantilever beam and slab) do not transfer togeth
If you see the slab deflection value it will a little than the beam,
Hi Ammer,
In order to see beam-slab deformation together on 3D View, rigidity of slabs need to be considered in anaysis model. for doing so, you need to apply semi rigid diaphragm analysis on Analysis Settings. (see that 6mm deformation on middle edge of cantilever slab which has maximum value, purple colour)
    21.2 KB · Görüntüleme: 3,132
    42.2 KB · Görüntüleme: 3,132
    65.1 KB · Görüntüleme: 3,133
Great job,
so for checking the total deflection from the beam report as show below
this values for the beam deflection including the slab deflection?!!!
    241.8 KB · Görüntüleme: 3,106
Hi Ammer again,
your "beam deflection including the slab deflection" is not right question. That value is total deflection of beams which comes from anaysis model in which shell elements rigidity may include or may not include.
TotalDeflectionOfBeams = TotalSuddenDeflection+TimeRelatedDeflection=5.36+1.07+9.94=16.37 mm according to your screenshot.
I want to note that:
Semi diagram option: Slab rigitidy depends on it's height and slabs include analysis model. all are in together analyze. (shell elements include )
Full diagram option: Slabs has infinite rigidy, loads of slab are set to beams and then program analyzes the model. (shell elements doesnt include but theirs loads)
I'm asking if
The beam deflection for only beam
Or the slab deflection is same the beam deflection?
Sure. Must be At the same node the beam displacement and slab displacement is the same value
HELLO
I checked the slab report,and i found that the deflection values did not changed even when we set the semi rigid
how to solve it?
    135.4 KB · Görüntüleme: 3,032
    122.5 KB · Görüntüleme: 3,033
Hi ammer,
Deflection values are changing on either analyizing with semi rigid or full rigid diagram options.
from my sample projects:
I guess we cant understand us each other exactly. I can connect your pc to show the answers of your questions via Teamviewer. Please send me an email when you are ready.
    26.4 KB · Görüntüleme: 3,014
    27.8 KB · Görüntüleme: 3,014
