Beam stiffness modifiers for vertical load
ammer
Kıdemli Üye
dear sir
would you please show us where the stiffness modifiers for vertical load are uses?? :shock: :shock:
thanks
    89.4 KB · Görüntüleme: 1,880
There is no any section about stiffness modifier under vertical loads in Ts500 . But Turkish sismic code new version 2017 and ACI . ETABS also has this functionality about Stifness modifiers.
Normally you dont need to change this settings, leave them unchecked but if you think that beam may crack under the related to loads, you may reduce modules of elasticity or moment of inertia.
