Can I get Ss AND S1 for Iraq?
ammer
Kıdemli Üye
dear mr. hakan
Can i get Ss AND S1 for Iraq?
lat:35.455218
lon:44.403336
and i have an issue with code 2018 wizard
i can not set the R factor
please see the pictures
the project link here
    273.2 KB · Görüntüleme: 434
    247.2 KB · Görüntüleme: 434
Hi Ammer,
Unfortunately you can't get Ss and S1 for Iraq, because this map is only for Turkey. But you can choose a point which is appropriate for Iraq in Turkey border.
Turkish Seismic Code doesn't allow your structure to build one way ribbed slab. You should choose beam-and slab sturctures - waffle slab. Next step ise semi-rigid, ductility high and A11 -Special Moment Frames.
Please follow above steps and there is no need to change structural system.
İf you want to set R as an ordinary ductility, you should not use wizard. You can set it in Analysis Settings - TDY Options page, fill the boxes in red line.
Or you can choose 2007 code and enter the structural information like as 8.62 version.
    36.7 KB · Görüntüleme: 396
    57.2 KB · Görüntüleme: 397
    526.3 KB · Görüntüleme: 396
    400.4 KB · Görüntüleme: 397
  • kirkuk apartment-V10.ide10
    29.2 MB · Görüntüleme: 50
