How to draw the separated flat slab?
ammer
Kıdemli Üye
dear all members
i would like to show me to how i draw the flat slab edge or separated flat slabs so can i check the deflection and the reinforcement on the cantilever
plz check my attches
thanks
ammer":2u7nlult' Alıntı:
dear all members
thanks
Hi Ammer,
There are no defined slabs in your project. Please define your slabs in your project and mark your questions on it or add some pictures that we can answer your question precisely.
hello mr. hakan
i want you to draw the separated flat slab for this model not by one part
or my query is to assigning the edge slab line from center of columns or not?
thanks again
ammer":1lhtqzjy' Alıntı:
hello mr. hakan
thanks again
see the project I added above then.
many thanks mr hakan
one more question
in the reports,where can i find the slab punching check?
thanks :D :D :D
ammer":3hp0xq6y' Alıntı:
thanks :D :D :D
Hi Ammer
There are some beams on story in your project beside beamless columns. In this case, in order to see punching check for beamless column, you need to define column supports for per beamless column.
After analysis, you will see punching checks on slab report
    368.3 KB · Görüntüleme: 3,262
dear hakan
do you mean that i assign a zero depth for the panel as a clip below ?!!!
    138.8 KB · Görüntüleme: 3,229
MANY THANKS DEAR HAKAN
SO, AS I UNDERSTAND YOU,I WILL ASSIGNING THE CAPITAL COLUMN ONLY FOR PUNCHING CHECK AND AFTER THAT ,WE SHOULD DELETE THEM ?!!!! :) :) :)
ammer":9bp8bn4s' Alıntı:
you may delete them but if you do so, you dont see slab punching checks on report. You may leave them. they effect nothing on your project but punching checks
Re: How to fix this issue ???
dear hakan
while i'm modelling the flat slab and assigning the concrete directions,i got this error
please need your tips....
down load the model from her:
    232.8 KB · Görüntüleme: 3,155
Hi Ammer
See the explanation on enclosed picture:
    75.3 KB · Görüntüleme: 3,146
