1. Click Settings/Preferences, see drawing limits on Grid&Limits tab.
2. Enter X and Y co-ordinates for lower-left and upper-right corners in the appearing dialog. The rectangular area including the diagonal defined by these two points is the area defined by the drawing limits.
3. Click General tab on same dialog. see "Apply settings to all drawings windows " option on there. If you want the drawing limit settings to be applied in all existing windows in the project, check "Apply settings to all drawings windows" on the dialog. If you want the related settings to be valid only for the active window, leave it unchecked.
4. Click OK to exit the dialog.
IT WAS USEFUL......I HAVE ONE MORE QUESTION
WHEN I IMPORTING DWG TO IDECAD...THE CAD ORIGIN DIDN'T MATCH ON IDECAD ORIGIN....
SO,,,HOW CAN I SOLVE THE ISSUE AND HOW CAN I MOVE IDECAD 0,0 ORIGIN????
