How to rearrange the columns labels?
ammer
Kıdemli Üye
hi
i would like to rearrange the columns and should be aligned and continuity as below image
    115.2 KB · Görüntüleme: 153
1-)
-Run the "Label entities" command.
-Name the object in the dialog that opens.
-Select the columns in the order you want to name them.
-Press the enter key to terminate the command.
2-)
-Select the columns on axis B. Run the "Auto Label entites" command. In the dialog "Check Generate labels for this story" Click OK.
"Auto label entities" dialog will open. Give a name and "check left to right" option
Then select the columns on the D axis and Run the "Auto Label entites" command again.
Give a name and choose "Right to left" in the dialog
    43 KB · Görüntüleme: 141
    2.3 KB · Görüntüleme: 141
    43.1 KB · Görüntüleme: 140
    8.6 KB · Görüntüleme: 140
    11.1 KB · Görüntüleme: 140
    16 KB · Görüntüleme: 141
hi dear
unfortunately, it did not work with me
i want to be corrected automatically for all stories
