How to solve beams not continuity
ammer
Kıdemli Üye
hello
the attache model,i got an issue
how to solve beams not continuity?
what happen if i neglect it?
thanks
  • sohaib-waffle.ide85
    sohaib-waffle.ide85
    1.2 MB · Görüntüleme: 465
    300.4 KB · Görüntüleme: 1,290
ammer":ywcf3q1n' Alıntı:
You need to set balance between waffle beams. In order to do that, if you use waffle slab, you need to use waffle slab on it's adjacent slab and define same starting point values for each waffle slabs.
You may see how we can do this in example project that I added message below. I recommend that you should use semi rigid diagram method to analysis system.
If you neglect "not continuity message", all beams will be analyzed on their location and you will see analysis result from them. Also you cant draw waffle beam's details with continuity, which they will be separate in their details. You should define them as it should be.
hi mr. hakan
thanks to your efforts
i understand you that all black typical beams line should be in a line?
    112 KB · Görüntüleme: 1,244
