İsmail Hakkı BESLER
Administrator
![1.png](https://forums.idecad.com.tr/forum_blog_image/1.png)
ideYAPI Ürünlerinin Yapı Bilgi Modellemesi (BIM) Uyumluluğu (IFC 1.5.1) 19 Yıl Öncesinden Almanya'da düzenlenen IAI Endüstri Günleri etkinliğinde sertifikalandirilarak belgelendi.
IFC Ne demek ? Aşağıdaki linkde anlatılıyor;
Giriş yap veya üye ol.
ideCAD Structural 5
Developed in Turkey for structural designers of tall buildings, ideCAD Structural 5 is integrated analysis, design and detailing software for reinforced concrete constructions. It covers all relevant phases, from dynamic analyses to design of reinforced concrete cross-sections. Reinforcement details are automatically generated. A joint platform on the Web allows collaboration between structural engineers and architects. Users design and plan using real components such as walls, windows, columns, beams and foundations. A 3D user interface displays both 3D building models and their related analysis results for evaluation. This integrated visualization ability supports not only creation of renderings and animations, but also smooth and simple project planning. Static calculation and reinforced-concrete measurements are carried out on the basis of the 3D calculation model. Compatibility with IFC, DXF and DWG enables exchange of data with other CAD programs
ideCAD aus dem Hause ideYAPI nun mit IFC-Zertifikat
(16.6.2002) Im Rahmen des 6. Industrietages der International Alliance of Interoperability (IAI), der am 12.6.2002 im Congres Center in Düsseldorf stattfand, ist ideCAD aus dem Hause ideYAPI für die IFC-Version 1.5.1 zertifiziert worden - konkret:
ideCAD Architektur und
ideCAD Statik
Das türkische Unternehmen, das durch ein in Hannover ansässiges Tochterunternehmen auch in Deutschland Flagge zeigt, unterstützt das IFC-Format, da es glaubt, dass der Erfolg des Unternehmens auf der gleichen Ideologie basiert: "Integrated Design System" heißt nämlich die hauseigene Ideologie und sie steht für die direkte Verbindung zwischen Produkten und Teamworktechnologie.
Hintergrund: ideYAPI Ltd., mit dem Hauptsitz in Istanbul und einem weiteren Büro in Bursa, ist mit General Manager Dipl.-Ing. Ismail Hakki Besler an der Spitze seit 1988 auf dem türkischen Markt tätig. Die Zahl der lizenzierten Kunden in der Türkei beläuft sich Unternehmens-Angaben zufolge auf mehr als 7.500.
Das Unternehmen hat am 5.2.2002 das bereits erwähnte Tochterunternehmen in Hannover mit dem Namen ideCAD software GmbH gegründet. Diese Tochter ist der offizielle Distributor von ideYAPI- Produkten im deutschsprachigen Raum. Trotz der schwierigen Marktbedingungen vretraut ideYAPI dieser Strategie des Channel-Developments.
Das Unternehmen ideYAPI vertreibt fünf Produkte in Deutschland.
Das Hauptaugenmerk liegt dabei auf ideCAD Architektur. Die CAD-Lösung für Architekten ist derzeit mit der Version 4.01 auf dem Markt. ideCAD Architektur ist für die Projektbearbeitung entwickelt; das bedeutet, für die Phasen Entwurf, Ausführung / Werkplanung und Präsentation. IdeCAD Architektur unterstützt das IFC-Format sowie den Import und Export von DWG und DXF- Dateien. Das Programm arbeitet mit echten 3D Bauteilen und Geschossen, hat eine 3D Benutzeroberfläche und unterstützt die Teamwork-Technologie.
Das Softwarepaket ideCAD Architektur enthält neben den Architektur-Paktet zwei weitere Programme aus dem Hause ideYAPI. Zum einen die Animations- und Visiualisierungssoftware ideRENDER sowie das Fenster- und Türendesignprogramm ideDIO.
ideCAD Statik ist eine Tragwerksplanungssoftware, die für Bauingenieure und Tragwerksplaner entwickelt wurde. Sie unterstützt als erste Tragwerksplanungssoftware auf dem deutschen Markt das IFC-Format.
Das ideTEAM- Modul bietet Bauingenieuren und Architekten die Möglichkeit, zeitgleich am selben Projekt via Internet oder LAN zu arbeiten.
Übrigens: An der Implementierung der Version 1.5.1 sollen 3 Mitarbeiter des Unternehmens mitgewirkt haben. Die Implementierung gewährleistet die volle CAD view-Unterstützung. Dem Anwender wird zudem die optionale Beibehaltung der IFC-Historie gewährleistet. An der Implementierung von IFC 2X wird derzeit weitergearbeitet.
