"onay geometrisi" çıkış mesajı açmak için nasıl
ammer
Kıdemli Üye
Ben onay geometrisi yaptığınızda, ben mesage pencereden dışarı bulamıyor.
senin tavsiye ihtiyacımız
ammer":3f30ncus' Alıntı:
Hello ammer,
I figured you are doing geometric control but didn't understand what happened after that. You can write here as English all the time if you prefer.
You cant export geometric control's messages to text but you can change size to bigger size of geometric control dialog by expanding with mouse and take screen shot ...
hello hakan
during checking the model by "check" option>>>suddenly the message window are disappeared from main window...i tried to restart the idecad but the same issue.
ammer":35vgfhzp' Alıntı:
hello hakan
Message window might be stayed out of screen.
Start program by pressing left "ctrl + shift" in same time. Don't release "ctrl + shift" till resetting window's appearing, click ok. Program will start. See if it is fixed.
